Thread: No release
Old 11-17-2006, 06:52 PM   #5
west_side_supra
west_side_supra's Avatar
ok so what i have done is cut the spring inside of it. thinking that maby there may have been to much tension on it, and not enough pressure. well its on that track the spring now has about 2 coils cut off of it, and its still not opening. so now what i wonder is where can i buy a spring for the inside of this bov, maby a less tense one. i know hks has one for the racing pop off BOV but not the ssqv. is the spring for the pop off one the same?
oh i also lubed it up and it still would not open up.
7MGTE - 500hp never dyno'd
fidenza cam gears
