Old 11-16-2006, 06:07 AM   #1
tellfromchico,ca
tellfromchico,ca's Avatar
tellfromchico,ca is on a distinguished road
Red face
make sure and check out the water pump theres a drain hole on top in case the seals are worn out, that way it is visible for inspection. if there is a water leakage than change out the pump because it might seize on you. that might also solve your weekweekweek sound
ps make sure to tighten the alternator tensioner
tellfromchico,ca is offline   Reply With Quote
