Thread: engine swap
Old 11-16-2006, 03:49 AM   #1
burton51m
burton51m's Avatar
this isnt sumthing you just plop right in...you have to do a lot of fabricating.
you need..
1 2jzgte obviously
2 harness both the 7m and the 2jzgte
3 u need a 89+ round mount cross members some 89s do have square mounts to beware of it
4 turbo headers or manifold for a single turbo (unless u plan of fu<king up the fire wall)
5 turbo ur choice
6 motor mounts the 2jz
7 ecu-either stand alone or 2jzgte
8 fuel pump either the tt fuel pump or a walbro 250lb
9 elec fans cause the 2jz does not use the sameones also helpsout on parasitic hp drop
10 hybrid clutch and fly set up (if using manual)
11 tranny (well depends either 1jz bellhousing for the r154 out auto tranny or a getrag-v160 which involves alot of work)
12 ic
13$$$$$$$$$$$$$$$$$
