Thread: sunroof
Old 05-09-2005, 02:43 PM   #1
KingDiamond
KingDiamond is on a distinguished road
if you can access them check the bolts on the sides near the back of the sunroof, mine came with aftermarket also, and i found one bolt was missing, and the other was loose. I still need to adjust it, but it works now. If you can't access the bolts with the roof closed, try to push the button to the open position, and very gently push up on the roof, this might help open it, and then hopefully you will be able to solve your problem.
KingDiamond is offline   Reply With Quote
