Thread: new clutch
Old 11-07-2006, 03:59 PM   #1
tone loc
tone loc's Avatar
tools you need are a jack, transmission jack (buy or rent the one adaptable to a regular jack), jack stands a really nice socket set (most of the hard bolts are 14mm), get 2 14mm wrenchs too, and if your exhaust is really rusted badly you have to cut the bolts that are holding the cat to the downpipe. i took it to a shop to get that done and they used like a grinder to just grind them off($22). driveshaft you can just put a 14mm wrench or the rachet and just get out from under the car put your foot on the wrench and put pressure on it.(it will come losse.) when you get all the bolts loose then use a mallet and hit it a few times and it will come off. im working on the starter right now so thats all i can tell you.
