Old 11-06-2006, 03:31 AM   #1
jfunez
jfunez's Avatar
jbandson..you said you replaced the front crank seal allready..not the cam seals.
you will have to remove the top timming cover and then the two cam gears, try to pull them out,if you cant probably you will need to remove the valve covers and then unbolt and remove the camshafts.the seals will come attached to the cams and can easily be removed...remember to keep all the parts in their respective order.
Name:	front cooler.jpg
