Old 11-02-2006, 09:55 PM   #1
SupraDupra
SupraDupra's Avatar
Possibly knocked out a breaker on the fuse panel?
From my Supra manual...
"To reset a manual circuit breaker, first disconnect the cable from the negative battery terminal.Remove the circuit breaker, insert a pin into the reset hole and push in..."
Unfortunately my scanner is not working at the moment ,but it's a semi-round block with a hole in it.Best of luck to you.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
