Old 11-01-2006, 04:55 AM   #2
jfunez
jfunez's Avatar
you should of used your original harness... it worked with me..
the othe differences are one or two sensors on the thermostat housing and the lack of EGR valve.. other than that..all the sensors hook up straight with out differences...also make sure you are routing the harnes between the injector fuel rail and the intake plenum..
