Old 10-26-2006, 08:59 PM   #3
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Originally Posted by Supra2NR
no offense, or to shoot down ur idea, i ddnt even look thru the website
but im guessing a cold air intake from those companies will be around $200?
a lot of pple have did it already
why not jus make one for ur self?
pipes; mandrel bent or welded, from a muffler shop
the converter , so u can attch 3 inch pipes to the afm
rubber couplers, metal clamps, and a cone air filter
and u got urself a cold-air intake
In order for it to be cold air he needs to route it to the inside of the bumper or get a heat shield just slaping on a cone with a modular intake is not cold air.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
