Thread: help please
Old 10-21-2006, 10:50 PM   #1
hangsupra
Originally Posted by supra1985turbo
Dose it smell like gas? If so you have a fuel leak in your engine compartment. It is not tipical to smell fumes in the car unless you have a leak. If it dose not smell like gas you might have an exhaust leak near the engine. What kind of fuel milage do you get? You could also have a leaking injector. Pull your oil dip stick and spell the oil on it. If it smells like gas than you have a leaking injector. If you do might as well replace all 6. You can usally find them on ebay for the 5MGE. If not look for the ones for the 7MGE or 7MGTE. they are higher cc's and will fit like the 5M's injectors!
i know that the 7mgte injector... will fit.... but what about the wired... does the stock wired harness snap on without cut n re-connect the wired....
