Thread: tail-light help
Old 10-19-2006, 01:25 AM   #3
hangsupra
Originally Posted by Multistrada1
The problem is likely under the hood. Mine just did almost the same thing except mine had taillights but not brake lights. I looked all over and could not find anything wrong. The mechanic found a loose wire that had broken its solder connection. They found it in a hard to check place under the master cylinder.
huh? under the master cylinder... is it the brake or the clutch cylinder...
