Old 05-01-2005, 06:56 PM   #1
monkihead
SP58GT
monkihead's Avatar
Originally posted by roscoa1@Apr 24 2005, 11:49 AM
1. There is a slight tapping noise at idle - is this normal?
2. On acceleration there seems to be a rattle at 3000 rpm - 3500 rpm from the rear left side of the engine (lower), after this point it goes - a very loose rattle at that (mechanical)
3. On starting the ignition just clicks and after several attempt will fire up no problem... could this be a poor terminal connecting.
1.&2.the tapping noise may possibly be the lifters inside the engine. as you rev it, more oil pressure may quiet them-which is not good. they should be quiet all the time.
monique- better off dead
