Old 10-13-2006, 12:14 AM   #1
rnoswal
rnoswal's Avatar
You don't have to remove the turbo, but you do have to move a few items under that area to get at the line. You might as well change the metal gasket while you are at it though. I think I pulled the lower intake hose and pipe from the bottom of the turbo along with the oil filter and a few other braces and then undid the line that goes into the block.
Hope that helps some.
Russ
