Old 10-12-2006, 01:20 AM   #1
nelly26
nelly26 is on a distinguished road
Thumbs up
Toyota Supra Mk III (1986-1992)
In the middle of 1986, Toyota was ready to release its next version of the Supra. The bonds between the Celica and the Supra were cut; now they were two completely different kind of models. The Celica changed to front wheel drive (FWD), while the Supra kept its rear wheel drive (RWD). Though the A60 (Mk II) and A70 (MK III) had similar designs, the engine was a more powerful version than the earlier 2.8L and 3.0L engine with two versions*: one with a CT-26 turbo (the 7M-GTE) and one without (the 7M-GE). The non-turbo 7M-GE models came standard with the W58 manual transmission, and the 7M-GTE came standard with the R154. Both were available with an optional automatic transmission, the A340E. During the 1989 year, the car received new tail lights, front bumper, badging and side trim amongst other features.
In 1988 the Turbo-A model was introduced, it was a special design aimed at winning the Group-A touring car championships around the world. There were only 500 Turbo-As ever made. The Turbo-A was a special 7M-GTEU with 267PS (263hp/196kW), making it the fastest Japanese road car until the Nissan Skyline R32-GTR was introduced. The Turbo-A model was only produced in black, all featured leather interiors, a front intercooler inlet, were hardtops and only used MAP engine sensors. Other enhancements include higher boost (7.8psi), long lift cams, larger injectors, larger intercooler and a high flowed version of the CT26 turbocharger.
The A70 Supra was also available in two non export models in Japan, the JZA70 with a 2.5L 280hp (209kW) twin-turbo 1JZ-GTE, known as 2.5GT Twin Turbo R (JZA70), and with a 2.0L 210hp (157kW) twin-turbo 1G-GTE.
The third-generation Supra represented a great deal of new technology. In 1986, Supras were already equipped with ABS, TEMS (Toyota Electronically Modulated Suspension). By 1990, airbags became standard.
The 7M-GE MA70 is capable of propelling itself 0-60 in just over 6 seconds with 6.8 psi of boost.
Some possible chassis codes are: A70, MA70, MA71, JZA70, GA70
nelly26 is offline   Reply With Quote
