Thread: Buying a Supra
Old 10-10-2006, 05:07 PM   #16
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by GR0614
im sorry, i meant a single turbo compared to a twin turbo, what one would be more eaiser to mod...
If you're talking about mk4 supras (and not mk3 supras), since every & all single turbo mk4 supras have already been modified (otherwise there's absolutely no way a single turbo could possibly be on there), I guess you could say that overall (for the most part) a single turbo mk4 would probably be easier to re-modify. Taking those stock twins off is tough. On the other hand, the lower exhaust manifold nuts are a bit harder to access with an aftermarket tubular header though...and of course you'll probably pay more for a pre-modified single turbo mk4 supra.
...keeping the stock turbos?
Again, if you're talking about mk4 supras (and not mk3 supras), the only way you could "keep the stock turbos" would be to purchase a twin turbo mk4 supra, since every & all single turbo mk4 supras have already had the stock twins removed.
If you're talking about mk3 supras, then the vast majority of them are not equipped with stock twin turbos: most of them came with a stock single turbo (or n/a). The only exception is the relatively rare (especially in the US) 1jz-gte twin turbo...but those are non-sequential twin turbos (versus the sequential twin turbos in the mk4 tt).
I hope that helps to answer your question, although I'm still not sure that I understand exactly what you're trying to ask...
Life begins at 30psi.
