Thread: OD/off light
Old 10-10-2006, 11:41 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 8Ball
It still is in place the guy that had the car before me had the TRAC system disabled. But not by pulling the fuse. I am still not sure what he did. No matter how the trac off button is the trac and tracoff light seems to have a mind of its own. My speed does cut out at 155mph or so as far as I can tell. 8Ball.
Just a couple of suggestions: Check under your ecu cover and see if your trac ecu is still there. Also ensure your harness is plugged into both the trac motor and the secondary tps on the throttle body.
Life begins at 30psi.
