Old 10-05-2006, 05:03 PM   #3
Isphius
Isphius's Avatar
You should learn a little more and do some reasearch before you attempt an engine swap lol. The easisest thing to do, If you have all the tools, Is either pull your motor out, Or buy another, And rebuild it. But, You might have to get a new crank if yours is fried too bad. Youll most likeley need a new connecting rod too. The rebuild will probably cost 1000-1500, Depending on what you rebuild. But while you have the motor out, Do the HG, water and oil pump, timing belt, valve cover gaskets, Make sure all the sensors are good while you can reach them, ETC.
