Thread: Buying a Supra
Old 10-03-2006, 01:10 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Z4Dave
I`ve done a few Searches Got some good info on buying a supra
timming belt, Head gasket, ect
any thing you would like to add please do!...
Who told you that you should be concerned about the oem head gasket in an MK4? That info is completely inaccurate. Also, with proper maintenance, the timing belt shouldn't be an issue either. Look for proper maintenance records, and do a compression test especially if you consider a tt. Fwiw, I'd also advise you to have either an MK4 Supra specialist, or an ASE certified Toyota mechanic (or both) look at it before you plunk down the cash...
...in a 1995 non Turbo is the engine size different than the turbo engine?...
No, they're the same displacement...but compression ratio, ignition system, and head configurations are very different.
Life begins at 30psi.
