Old 10-01-2006, 04:42 AM   #1
Supra2NR
Supra2NR's Avatar
you can drill the bolt that was left in the hole
you jus gotta be really careful not to drill the metal around the hole
jus pick a small bit first, make sure you got a pilot hole so when you drill it,
the bit wont be dancing around
jus go slow, and eventually the bolt will be thinned out and you can jus get it off with sum pliers or anything that can grab it
