Thread: 1jz 2jz 7m
Old 09-27-2006, 04:34 AM   #1
midwestmk2
midwestmk2's Avatar
Exclamation
With the right mods you can have more power in your 5/6m motors N/A than a some boosted 7m's..Because the 5,6m's have the 12 valve setup the valves are larger and can withstand more heat build up than the little valves in the 24 valve 7m heads..A 5/6m motor can be pushed to 240hp easily with the right internal mods..Cams,pistons,rods,port@polish,etc..Now with a turbo thrown in there you will be able to desimate almost any 7m..Because the valves can handle more heat that means they can also handle more boost..So build up your bottom end get some forged pistons and boost it on up and kick ass in your MKII that is already got the weight advantage over the PIG and JellyBean!!
