Thread: tranny switch
Old 09-23-2006, 07:05 PM   #2
rnoswal
rnoswal's Avatar
You are also going to have to cut the shifter hole back about an inch too. The Auto wiring has to be reworked to make the backup lights work along with the park/driving wiring to get it to start. I think the speedo cables work ok but the cruise won't work now with the different pickup mounts. You will need to make a boot cover that goes over the rubber boot to keep the heat out.
I don't think there are any provisions for the clutch pedal enable start switch either. So make sure it is pushed in or in neutral when you start the car. It is a lot of work, but I did it and it worked out pretty good, but I think if I had to do it over again, I would just sell the car and by a manual. The auto is pretty good and it is nice having cruise control.
Good luck
Russ
