Old 09-23-2006, 03:55 PM   #3
rnoswal
rnoswal's Avatar
There is a starter relay behind the passenger kick board. The starter ockout switch might be unplugged if it is a manual. I it used to be an automatic trans then you may need to disable the auto lockout (only starting in park). Get someone to turn the key and check the wire that goes to the starter solenoid then make sure the main power cable does in fact have power to it.
Good luck and let us know how it goes.
Russ
