Old 09-18-2006, 08:35 PM   #1
midwestmk2
midwestmk2's Avatar
Your best bet is to turn the crank to TDC and make sure the timing marks for the cams are alighned properly..You can then adjust thetiming with a light and the distributor..On the tps though i just moved mine little by little until i was satisfied..
