Old 09-18-2006, 06:10 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by supra90turbo
GE heads are different than GTE heads on the 2JZ's?
If that's true, that sucks.... AFAIK they were the same...
No they are different...significantly different. One has a distributor and the other has coilpacks. One has exhaust ports angled to spool up twin turbos, and the other has evenly spaced, straighter exhaust ports. I'm not sure where you heard/read that they were/are the same, but that source is incorrect.
What you posted above is 100% correct: "If you want plug and play, you'll need a kit for a GE."
Life begins at 30psi.
