Old 09-18-2006, 06:04 PM   #1
SolidStateS15
SolidStateS15 is on a distinguished road
Originally Posted by midwestmk2
I would say since he replaced the TPS then he just put it on with out adjusting it..Check it out then i would say check the timing also..
yeah what i was thinking too, and it also looks like the timing belt was replaced not too long ago as well so it should be fine but i can check. is there a voltage chart in the shop manual for adjusting the tps? also can i check the timing with a light, or is it more complicated like some other engines that are electronically controlled.
SolidStateS15 is offline   Reply With Quote
