Old 09-18-2006, 02:11 AM   #1
Isphius
Isphius's Avatar
Do you have a turbo? Its on the passenger side where the distributor is on the na. Its at the front of the block right behind the thermostat housing. It has a plug coming out of it, and it looks like a distrubtor except without the spark plug wires. Then you need to get a timing light(follow timing light insturctuons), But there 40$ or so if you dont have one already. and to set your base timing. Im not sure exactly what its supposed to be, Ill find out what its supposed to be
