Thread: Slow Start
Old 09-17-2006, 06:17 PM   #1
Isphius
Isphius's Avatar
And weezl, Mine idles up to 1500 rpms at times, but it wont go below 1100. So do you think it could be my fuel? the car runs great when its under boost and just cruising, Its jut when i let it fall below 1k rpms about. And i tested the cold start injector sort of, so i think it works fine, Because when i crank it, I took the 3000 pipe off to see if it worked and it smelled like gas, So im guessing it was squirting gas in.
