Old 09-16-2006, 02:46 PM   #1
Burn N' Up
Burn N' Up's Avatar
There is also coolant that runs through the intake manifold and plenum from a 1/4" whole on the intake side of the head between the intakes for chambers 1 and 2. I had a leak there and it ran down the block but I suppose it's possible for it to get pulled into the intake manifold as well. Otherwise the ISC valve i would definetly check. Only two places that coolant cruises around.
Why Mr. Toyota decided to deviate from his usually infinite wisdom and but a F'in coolant whole that has to run through the intake manifold I don't know, fittings and a hose seems much easier although not as clean looking...
89Turbo 5 speed:Eibach lowered,Tokico Illumina II TEMS,All Poly Bushings,3" Elbow/DP/Cat,HKS Sport Turbo Exhaust,K&N FPIK w/ AEM Dryflow,Cooleeze ceramic coated Turbo inlet Pipe and 2.5" hard IC Pipes,Custom 2.5" fitting Spearco IC,HKS SSQV BOV,Greddy 1.5mm MHG and timing belt,Magnecore Comp Wires,NGK IR Low-temp Plugs,ARP studs,Dual Flex-a-lite fans w/ thermo switch,Fluidyne Rad,PCV VTA,Stage 3 F1 Racing clutch,Stainless braided clutch line and brake lines,Drilled & slotted rotors,EBC pads.
