Old 09-14-2006, 03:48 AM   #14
Isphius
Isphius's Avatar
Haha yeah the AFM takes authority over all the other sensors. The other ones just kinda add to what the ECU does after reading the AFM signal. And reeves, your friend is probably referring to real "chips" Like the ones giac makes for the vw/audi turbo cars for example. Not ebay chips. And yes those do work, But i dont think anyone makes one for our cars. And most of what those chips do is turn up the boost and fuel curve to compensate because the boost is ECU controlled on most newer cars (DSMs, audis, vws, turbo diesel trucks, etc), But you can still use a boost controller to modify the air pressure to the wastegate. Our turbo supras run purley on mechanical boost control, And the ecu will just cut fuel if too much air goes through. The only chip equivalent we can get for our cars are things like the maft pro, safc-2, and things like that. Suprra girl just mentioned them.
