Thread: damaged engine
Old 09-12-2006, 05:22 PM   #14
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Seanchp
Hey pwpanas! You were right on the spark plugs! I changed them friday, and my car is now running better than it ever has! You are the man!
Thank you for your kind words. Again, if you used copper plugs, be sure to change them every 5000 miles.
Let me ask you, what kind of boost controller do you have??
I'm currently using a manual boost controller (Hallman), but I'm planning to get my AEM to regulate my boost soon (I've already purchased the solenoid, etc.). For bpu Mkiv Supras, I usually recommend the HKS EVC-EZII.
what is you boost pressure??
I typically run anywhere from 15psi through ~40psi, depending on the octane fuel I have in my tank, and the application. Although ~40psi is cool for a dyno run or dragstrip, 30psi or so is max practical for getting groceries.
...and wht internal mods do you have done??
Pretty much everything (except a stroker kit), since it's built for ~1200rwhp+ (note: I haven't dyno'd that high yet). You may already know that the oem 2jz-gte internals are good up to about 900rwhp through a 6spd (which is PLENTY of power for most applications).
...Oh! and thanks so much for your advise and help.
Again, anytime...glad I could help.
Please tell us some more about your Supra. How do you like your AVC-R boost controller? Have you ever tried more than 17psi with race fuel? Is your eManage dyno-tuned? Do you ever roadrace with those Teins?
Life begins at 30psi.
