Old 09-12-2006, 06:40 AM   #1
mrnickleye
mrnickleye's Avatar
Are you having any water boil over to the bottle regularly?? That is a sign.
The gasket usually leaks near #6 cylinder. When it fires, it pushes a tiny amount of pressurizes combustion gas into the coolant, which then get too much pressure, and blows water to the bottle.
This is why If it is a BHG, block seal will NOT work on our cars.
