Old 09-11-2006, 07:43 PM   #3
midwestmk2
midwestmk2's Avatar
The PVC idea is a good idea unless you want to pay $150 for a custom one..You can also have someone weld up some 3" exhaust pipe to recreate the bends of the stock one..Just delete the silencer canister and weld in some bungs for the the vacume lines and use an open type cone air filter..There is also a mod you will have to do to the MAF to keep the CE light from coming on..The reason why it comes on is because with the increased air flow you will be running lean..The MAF mod will increase the fuel flow to the motor and increase throttle response and acceleration.. Here is a link for the mod..
http://www.afn.org/%7Ewjh/tsc/supra/afmtune/afmtune.htm
