Old 09-10-2006, 04:11 AM   #10
drifterdude7
drifterdude7 is on a distinguished road
Originally Posted by Isphius
Yes, Its called a block tester kit. You forgot to tell him the name of it lol. You can get them at napa, carquest, pepboys, etc. All that test is to see if there is combustion byproducts in the coolant tho, Its not a 100% solid test. But if it does test out, there is a good BHG chance.
ya but when i had my test done i made sure that it was straight water in the radiator to be definate....he can also get a compression tester and put it in the number one spark plug to see if it compresses at default...you can go onto supra stats.com and look into what the stats are for it.....
drifterdude7 is offline   Reply With Quote
