Thread: damaged engine
Old 09-05-2006, 04:31 PM   #5
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 2JZ Beast
hey i am sorry i can't answer some of the questions asked cause i am trying to learn, i sent the car to be built to run under 10 secs on the 1/4 mile, i haven't even driven it yet and it got damaged, maybe when i get within the next month and a half, i will be getting all the technical details with it. i am just trying to learn about supras, so any advise will be welcomed, thanks.
Yep, and I'm trying to help by correcting some misinformation you might have been told by whomever you sent it to. I'd strongly suggest you get this cleared up so that you know for sure what you're paying for...
I also mentioned it because an 88mm overbore will weaken the cylinder walls (depending on how much boost & nos you're running). You need to be aware of this and ensure the shop takes full responsibility if your cylinder walls crack when you try to run in the 9s...
Life begins at 30psi.
