Old 09-03-2006, 05:00 PM   #1
jfunez
jfunez's Avatar
also what you can do is use an extension and a swivel socket from the front, under the intake to get to the bolt while holding the rear of the nut or socket (the transmission side) with a wrench or one of those ratchet wrenches.
good luck... its a lot easier when you have a lift or the intake manifold off the vehicle.
I'm surprised you could see and get to the solenoid wire,nut.
