Thread: making a 7mgte
Old 09-02-2006, 06:01 AM   #1
Isphius
Isphius's Avatar
Search around. The 7mgte has lower compression (necessary for boost) and oil squirters that cool and lube the rods and pistons. It is possible to get these machined into a ge block, But ive never seen it done, Just read about it. Otherwise, There is 2 knock sensors in the turbo block. I dont know how you would hook the turbo ecu up to one without it working right. You can run a turbo on an n/a computer and all, But I think you would need some kind of fuel computer to keep it fueled right and to run bigger injectors. If you can find a way to get the throttle body in front of the turbo, Youd be fine, It would run as factory.
