Old 08-31-2006, 03:14 PM   #1
Isphius
Isphius's Avatar
Snow is all about tires. My supra went great in the snow except for accelerating. But it turned and stopped fine. You just need the right tires, and your fine. If you can, Get light truck tires, In the smallest width they have that will fit the rims. Not sure on the mk2. i had 205/50/16 yokohama avids and they worked fine in all weather. Could use a little more traction in the rain, But dry and snow better than i would expect from such cheap tires. Having front wheel drive helps a lot, But you dont need it. And stay away from awd/4wd, Unless its a pickup. Only time that helps is when you get stuck. Now you have 4 tires spinning you out instead of just 2. I know that from experience lol.
