Old 08-30-2006, 07:00 PM   #1
Burn N' Up
Burn N' Up's Avatar
REPLACE YOUR EXHAUST VALVE GUIDES! I had my head, milled, tripple ground valves, Valve shim adjusment, pressure tested, acid bathed, and had the exhaust valve guides replaced, you can do intake too but usually they don't need it, the exhaust definitely though.
89Turbo 5 speed:Eibach lowered,Tokico Illumina II TEMS,All Poly Bushings,3" Elbow/DP/Cat,HKS Sport Turbo Exhaust,K&N FPIK w/ AEM Dryflow,Cooleeze ceramic coated Turbo inlet Pipe and 2.5" hard IC Pipes,Custom 2.5" fitting Spearco IC,HKS SSQV BOV,Greddy 1.5mm MHG and timing belt,Magnecore Comp Wires,NGK IR Low-temp Plugs,ARP studs,Dual Flex-a-lite fans w/ thermo switch,Fluidyne Rad,PCV VTA,Stage 3 F1 Racing clutch,Stainless braided clutch line and brake lines,Drilled & slotted rotors,EBC pads.
