Thread: N/a-tt Help
Old 08-28-2006, 11:37 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Turb0wned
Im still undecided of wether im going na-t or tt swap. I was wondering if someone could tell me how much im looking if i can get a 2jzgte (JDM) front clip locally for $3600, how much more on top of the 3600 am i looking at spending....? My supra is an auto, the front clip is manual, so i will have to do the auto to manual swap also...
Why not put your existing auto tranny on the 2jz-gte?
Is the 2jz-gte front clip from a Supra or an Aristo? If it's not a Supra, you'll have a bunch of work associated with adapting it to the Supra, including (but not limited to) the fact that the oil pans are very different. Also, is the ecu included?
Although it only takes an experienced shop about 3 hours to pull an engine (6 hours total, if it's a Supra/jza80 2jz-gte, for the engine swap itself), your biggest challenge will probably be related to the harness. The jdm harness is for RHD, and you'll need the jdm ecu to control the 2jz-gte engine. Your oem non-turbo harness will not work with the jdm ecu. Getting a new us-spec turbo harness from Toyota (about $800+shipping) would probably work.
If you decide to do the tranny swap, it'll be a lot of work ... pricey and very time consuming. More info on that here:
http://www.mkiv.com/techarticles/aut...wap/index.html
Life begins at 30psi.
