Thread: name that part
Old 08-08-2006, 12:37 AM   #11
OmeGa
OmeGa's Avatar
OmeGa is on a distinguished road
If it is just falling off due to rust its very easy to fix. Some of mine was falling off/bulging due to rust.
What you do is take the entire strip off that is rusted, clean off the rust out with a screw driver or something that you can scrape all the metal off with. Then you go but a can of "One Step" or primer to keep any rust from coming back, or running down if it rains ect. Then you silicone it back on, I used blue painters tape to keep it in place for atleast 24 hours. Then finaly you take some black silicon and fill in the top and botton to keep water from going under it.
That is the way to go if you can't afford all new stuff. I will say it looks a lot better than it did, but its not 100% perfect because I was in a rush and didnt clean all the rust out.
OmeGa is offline   Reply With Quote
