Old 08-05-2006, 04:29 AM   #3
theWeezL
theWeezL's Avatar
you need to be very careful when doing this. The bolt will be quite hard and unless it broke off pretty flat, its going to be hard to get a drill started going in straight. It will want to slip off the side and get into the aluminum of the manifold. Once you do that it becomes nearly impossible to get the broken bolt out.
Take your time, make sure you have a good sharp drill bit and stop if you think your messing it up.
____________
