Old 08-05-2006, 03:05 AM   #1
dcrusupra
dcrusupra's Avatar
89+ crossmember or motor mounts, 2jz water pump, pulley, fan, transmission, ecu, wiring harness, block, turbos, intake manifold, complete head, sensors, exhaust manifold, fuel rail, injectors, throttle body, ignition wires, power steering pump, timing belt from a 1988+ Isuzu Trooper 4 cylinder 2.6 liter engine (4ZEL), 2jz serpentine belt, driveshaft, diff., 2jz power steering line.
For the record, you'd be better off with the 5 speed R-154 tranny....
New Rebuild
My CarDomain
