Thread: Rear End Howl
Old 08-01-2006, 08:00 PM   #1
midwestmk2
midwestmk2's Avatar
Well if you dont want just one wheel to spin then you want a limited slip rear(AKA a posi)..Almost all of the p-types(with fender flares)came with a limited slip..All of the 82-86.5 supras,Celica GT's and most cressidas share the same rear diff..Now you say that it is howling..Does that mean that it is just howling through the chassis and body like a tire noise that 4X4's normally have or a grinding sound..If it just putting out a howling then you should just check out the bushings on the rear crossmember and other suspension peices..If it is grinding then it is definitly the rear diff then..
