fuel
I had a question about the areo fuel regulator kit. I know its adjustable but doe it react to boost pressure increase where the more boost is present, the more fuel pressure is given or does the regulator max fuel pressure is set at 0" vacuum. Also I got a 87 turbo supra and I raised boost to 10 psi, I got a walbro 255lph hot wired, will my car run lean or do I need a adjustable regulator.
