Old 07-31-2006, 03:29 AM   #1
gomezmk
gomezmk is on a distinguished road
to make the tach work, you have to pull out the cluster and take out the tach gauge, behind the tach is a small little box with resistors on them. On mkiiitech they explain which resistors have to be cut out and the ohm value to replace them with, I soldered my on. And for the driveshaft, I stuck with the na 5-speed so I left the drive terrain alone and so far it's worked fine. My na came with lsd when i got it.
gomezmk is offline   Reply With Quote
