Thread: Power Failure?
Old 07-22-2006, 09:52 PM   #2
theWeezL
theWeezL's Avatar
after you check all your fuses and circuit breakers, and are sure you have good juice in the battery, I would double check your grounds. Just having continuity is not enough, you can have continuity but not enough connection to provide adequate power. Resistance is the issue here.
____________
