Thread: Power Failure?
Old 07-20-2006, 11:58 PM   #2
Isphius
Isphius's Avatar
Yah, The red battery light turns on if your voltage goes lower than about 12.5 volts. Does any power come on or just no start? it could be a loose wire inside the alternator tho, Or somewhere along the positive/negative cables. The car needs a complete circuit to turn the fuel injection on too, so you cant even push start it. Just replace the positive and negative cables. They shouldnt be that much. There kind of a pain to reach tho. Also look at all ure fuses and breakers in the box next to the battery.
