Old 07-18-2006, 08:34 PM   #3
Isphius
Isphius's Avatar
They are all fed pretty evenly, The whole line is pressurized and the injectors it let it in as neccesary. With fuel, It can get hot and start to vaporize in the lines if the rail gets hot.big problem on a lot of straigh 6 motors. I dont think its your problem, But who knows. It does cause something similar to that, seems like a miss. It does sound like something electrical tho, If it starts to run bad and then gets hot and worse. Electronics like being cold. You might have a dry soldier joint somewhere, on the millions of solder joints. Thats where the lead isnt attached to the metal(really soldered and not fake), it just touched it enough to make contact and then heats up and expands outwards. Look for honda main relay resolder to see what i mean. Its a common problem on the main relay in the civic/integra
