Thread: easy question
Old 07-18-2006, 12:13 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by asnboi512
i have a 97 supra and i would like to know how to reset the maintanace required light...
Just pull the two fuses labeled 'EFI" in your main fuse box (engine bay, near battery). However, note that if your supra really does need maintenance, it's likely the light will come back on again quickly.
Here's a bit more info on troubleshooting the ecu codes that trigger the maintenance required light:
http://www.mkiv.com/techarticles/eng...bd1_codes.html
Life begins at 30psi.
