Old 07-17-2006, 12:50 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by bigjay
Im looking around for a supra. I want to know do you guy's think I should get a NA supra (cheap) and then upgading the engine or just pick up a TT ? Is there more option in the TT tant the NA ? I Know I definately want the sport roof... Any of you have problems like leakage ?
And also I would like to know what mods should be done ? In what order ?...
Starting with a TT in the first place is generally less expensive, if you want to end up with everything the TT has (including the bigger brakes, better driveline, etc.). Leakage problems with the targa are rare.
You'll find lots of info on the modifications to be done here:
http://www.mkiv.com/
...check out the "Faq" section and the "Tech Articles".
Life begins at 30psi.
